Orbi WiFi 7 RBE973
Reply
VPN service - apply button does not work Netgear X4S R7800
Polymorphic
Firmware version: 1.0.2.62
When i go to: Advanced->Advanced Setup->VPN Service
and click 'Enable VPN Service' and then click apply, i get a warning about DNS/Static IP.
However the setting is not saved.
Clicking 'For Windows' or any other button, just asks me to enable VPN service, and refreshing the page, shows that the setting isnt saved.
Assistance needed
Message 1 of 3
Accepted Solutions
Polymorphic
Re: VPN service - apply button does not work Netgear X4S R7800
Found the solution
If DDNS isnt enabled, the settings isnt saved.
It would be nice if the page gave that information.
This also kind of sucks when your ISP is assigning my static IP with DHCP.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 3 of 3
All Replies
Polymorphic
BTW - tried to reset to factory default, but there is no change.
Message 2 of 3
Polymorphic
Found the solution
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1141 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
