Orbi WiFi 7 RBE973
Reply
Warzone -- Port Forwarding for Multiple Devices
visualsoul
Follower
We are trying to forward ports for both our PC and PS4 to be able to play COD: Warzone. Right now, I'm only able to forward ports for the PS4 and we are able to get an open NAT, but I'm stuck on Strict for the PC. I've tried putting the PC in DMZ (I know, it's not recommended), just to try something else. Is there a way I can make both of these devices work properly or will only one be able to have port forwarding. Seems like there should be a solution available.
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 3
antinode
Guru
Re: Warzone -- Port Forwarding for Multiple Devices
> We are trying to forward ports for both our PC and PS4 [...]
   _How_, exactly?  Which ports?  To where?
> [...] I'm only able to forward ports for the PS4 and we are able to
> get an open NAT, but I'm stuck on Strict for the PC. [...]
   "not able" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
   If you're trying to forward some particular set of ports to multiple
destinations, then I'd guess that you're doomed, because that makes no
sense.
> [...] Seems like there should be a solution available.
   Seems as if there should be a better problem description, too.
Message 2 of 3
aaronibm21
Luminary
Buenas tardes, podrias decirnos que puertos y como lo has echo para configurar el xr500 los puertos del warzone??
Gracias!!
Model: XR500|Nighthawk Pro Gaming Router
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1330 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
