Rickyhu
Feb 10, 2021Aspirant
WiFi doesn't work on rax35
Hey everyone.
I have WiFi problem with my router. Internet works well, I can directly put cabel into computer.
One time, I lost my WiFi signal, I rebooted router and after that I have never seen WiFi signal again. I rebooted router and modem lotta times, but result same. I also can't go to the app cuz I don't have a WiFi. And if I'm trying to connect router to PC with ethernet cabel, but it wasn't help me.
I hope that I can fix this with you guys. Thank you in advance.
Have you tried a factory reset?
Push and hold reset for 7-15 seconds while its powered on.
- RickyhuAspirantYes and It doesn't work to:(
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
