jobin
Oct 16, 2019Aspirant
Wireless Settings 2.4 & 5 GHz Not found?
win 10 reports Wirless Network Router Not Connected
routerlogin.com report Router Info check, but Wirless Setting for both 2.4 and 5 are in red circle and X.
i can't figure how to adjust wirless settings.
anybody know?
thanks much!
dexter,
thank you very much!
i found one problem, a toggle for energy saving, in win 10, was on and needed to be off. once switched, i hard reset and the netgear app popped up and fixed the settings.
well, at least i think that's what happened! netgear site and genie diagnostics ain't universally wonderful.
it's not seeing 5G, but it's done that before, and it magics back after awhile.
jim
- DexterJBNETGEAR Moderator
Hi jobin, welcome to the community! You may find the links below helpful.
http://kb.netgear.com/app/answers/detail/a_id/24095
http://kb.netgear.com/app/answers/detail/a_id/24096
Dexter
- jobinAspirant
dexter,
jim
