Reply
Wireless security options with explanations
NetRags
Tutor
Hello Team,
I would like to have your knowledge base updated with the types of security options available in IEEE and supported security options on NETGEAR router with detailed description. The current article which is avaiable on your KB portal isn't that great enough. This is what I get when searched for security options..
http://kb.netgear.com/app/answers/detail/a_id/112/
and
http://kb.netgear.com/app/answers/detail/a_id/13205
I would like to refine your article with all the available security options starting from WEP, WPA-PSK[TKIP], Mixed, WPA2-PSK[AES] etc. I am not sure whether your knowledge base team consider my request or not. Even if they consider will I get any intimation after posting my suggested article in your support portal.
Thanks & Regards,
NetRags
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 4
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Wireless security options with explanations
@NetRags I will go ahead and forward this to the management.
Thank you!
ElaineM
NETGEAR Community Team
Message 4 of 4
All Replies
ElaineM
Hello @NetRags
Welcome to the community!
Thank you for your input. Can you tell me more on what would you want to see on these articles?
ElaineM
Message 2 of 4
NetRags
Tutor
Hi Elaine,
Would be better if we have the article updated with the below sample info
Wireless security types available in NETGEAR Gateways/Routers
1. WEP
2. WPA-PSK (TKIP)
3. WPA-PSK (TKIP) + WPA2-PSK (AES)
4. WPA2-PSK (AES)
5. etc..
Example:
What is WEP security?
> Definition
> Description about Key index (Key1,2,3,4)
> What is the purpose of Generate button when WEP security is selected
> etc
Prons
> Supported by almost all the wireless devices including Win-XP, Amazon Kindle etc...
> etc
Cons
> Low security strength
> Networking geeks can easily crack the password
What is WPA-PSK (TKIP)
WPA:
PSK:
TKIP
Prons
Cons
This information not just helpful your valuable customer also helps your phone support representative to get familiarize on these. So that they can avoid blabbering when customer asked about the differences b/w security types.
Thanks & Regards,
NetRags
Message 3 of 4
ElaineM
Thank you!
ElaineM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3460 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
