Reply
when do you use 2.4GHz vs 5GHz
Hogger2
Follower
Never used before and do not know the difference.  Thanks
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: when do you use 2.4GHz vs 5GHz
Read the article below too.
What is the difference between 2.4 GHz and 5GHz?
ElaineM
NETGEAR Community Team
Message 4 of 4
All Replies
VE6CGX
Master
2.4GHz band is older vs. 5GHz is newer band. As a result there are more users on 2.4 causing congestion of signals.
5GHz is still much less congested but has shorter range vs. 2.4. There is no rule which one should be used. Try both
and choose the better one for you.
Message 2 of 4
IrvSp
Master
Message 3 of 4
ElaineM
ElaineM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 19178 views
  • 0 kudos
  • 4 in conversation
Announcements
