× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Access Point / Range Extender / Repeater - NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE500)
NiteWatcher
Guide
Can this model router  (NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE500) | AXE11000 Tri-Band Wireless Speed (Up to 10.8Gbps)  be used as a   1) Access Point 2) Repeater 3) Range Extender And what are the processes to set up for each?
Message 1 of 7
Guru
Re: Access Point / Range Extender / Repeater - NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE50
1) Access Point---Yes
2) Repeater---No
3) Range Extender---No
the manual goes over placing it in access point mode.
Message 2 of 7
NiteWatcher
Guide
Ah so I can string   one as a router and 2 as   access points ...
Thank you so much.
Message 3 of 7
Guru
That'd be an expensive setup.
And it wouldn't work like a mesh system as that isn't a mesh router.
It might be worth checking into a mesh system like orbi or another one.
I've used the arris ax11000 mesh system. I've never used an Orbi AX though.
Message 4 of 7
NiteWatcher
Guide
1)So would the Arris  AX11000 work with the   NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE500) | AXE11000 Tri-Band Wireless Speed (Up to 10.8Gbps)   (https://www.netgear.com/home/wifi/routers/raxe500/?    This is the router I have purchased.
2)Or should I   stick with a  Netgear  (Orbi Tri-Band WiFi 6 Add-on Satellite, 6Gbps  https://www.netgear.com/home/wifi/mesh/rbs850/)   such as the following (even though they would not be able to get the 10.6 Gbps that the RAXE500 Nighthawk is capable of these satelite Mesh devices can only get 6Gbps.):
And  will the mess  work with the router I have purchased.
regards,
Message 5 of 7
NiteWatcher
Guide
I thought I would just add the following  (((NETGEAR Nighthawk WiFi 6 Mesh Range Extender EAX80 - Add up to 2,500 sq. ft. and 30+ devices with AX6000 Dual-Band Wireless Signal Booster & Repeater (up to 6Gbps speed), plus Smart Roaming)  to  work with my   (NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE500) | AXE11000 Tri-Band Wireless Speed (Up to 10.8Gbps) )   ((NETGEAR Nighthawk WiFi 6 Mesh Range Extender EAX80 - Add up to 2,500 sq. ft. and 30+ devices with AX6000 Dual-Band Wireless Signal Booster & Repeater (up to 6Gbps speed), plus Smart Roaming.
These  Netgear   EAX80   Mesh Range Extenders  are  touted to work with any Router.. so   let me know what you think ...
regards.
Message 6 of 7
Guru
I've never used the EAX80 so I can't attest to their performance. I will say they don't work as a mesh device when ran in access point mode.
Message 7 of 7
Discussion stats
  • 6 replies
  • 1601 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
