Pasquillus
Feb 20, 2023Aspirant
Devices on different bands cannot connect to Google Home
Router - RAX200
I have 1 x 2.4Ghz and 2 x 5Ghz channels, running using Smart Connect.
When the Google Nest connects through 5GHz-1, devices connecting through 5GHz-2 cannot cast Spotify to the hub, share with any devices on 5Gh-1, or see the Google Nest etc.
It's as if devices on different bands are on a different network.
Any way that devices on different bands can see each other on my Wifi? (preferred solution)
Otherwise, is there any way to disable one of the 5Ghz bands without disabling Smart Connect?
What router do you have?
What firmware is on it?
What modem/gateway is the router connected to?
- PasquillusAspirant
Thanks for response 🙂
Router - RAX200
Firmware - V1.0.10.140_1.0.79
Connected to modem - Technicolor TG789vac v2
I updated the firmware to latest tonight. I can no longer see 5Ghz connections from my router IP or through the android app. When my phone connects over 2.4Ghz I can't cast to the Google Nest, which is connected over 5GHz. After reconnecting the phone a number of times it finally connected at 5Ghz and was able to cast to the Google Nest (Signal strength at 100%, 2m from router, so not sure why it sometimes connects over 2.4). As stated, can't see 5Ghz devices so can't see which band any of them are connecting through.
That looks like a modem/router (gateway). Adding the RAX200 is an invitation to trouble.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.technicolor tg789vac v2 bridge mode - Google Search
Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
