chuck4100
Jan 01, 2020Tutor
How to determine the fan status on RAX120
Hello,
I have been getting some full failure type issues with my router recently, like reboots don't help but a full factory reset sorta did.
Mainly, I noticed that at no point have I seen the fan run at all. I fell confident that it had when I first got it back in July but now, nothing.
I have no Idea how to tell if it is broken or just not warm enough to run. I found the settings page 192.168.1.1/Thermal_FAN.htm so that I could try forcing it to run at any speed but the page gives me a "400 Bad Request" when I hit 'apply'.
If anyone has some guidance on this, I'd really appreciate it. Like, is it normal for the fan to be off at all? is there a way to set the speed?
- Fricke_IowaInitiateI am having the same issue. My router gets hot and then shuts down. The fan doesn’t seem to be running. How do I tell if it’s defective?
- Christian_RNETGEAR Employee Retired
Hello chuck4100 & Fricke_Iowa,
If your router is getting warm and causes the router to shutdown, I would recommend getting in contact with our Support Team for further assistance.
https://www.netgear.com/support/default.aspx
Christian
