nchoodam
Dec 29, 2022Follower
Is there a WDS capability in Nighthawk AXE11000 model
Is there a WDS capability in Nighthawk AXE11000 model, If yes. how do i configure it in AP mode.
I have another router which i need to connect to Nighthawk AXE11000.
Kindly suggest.
Wireless Bridge mode? IF so,
Thats under Advaced Tab/Advanced Wireless settings, scroll down to "use other mode" and select it. This will bring up a configure wireless settings for wireles bridge mode.
For AP Mode, review this:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Connect how? Wired or wifi?
Which AXE11000 are you talking about? RAXE500?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
