GrahamA836's avatar
GrahamA836
Follower
Jan 01, 2024
Nord VPN for RAX1-100NAS
What needs to be done to install Nord VPN on my new router. I am completely new to this personal  owned router. Seem to work much better than IPS supplied router. What to install VPN for protection.
  • michaelkenward's avatar
    michaelkenward
    Protection from what?
    There are lots of snake-oil sellers out there pushing VPNs.
  • schumaku's avatar
    schumaku
    So be happy with it!
    Protection from what exactly? Are you a politically exposed person, religiously persecuted, or under pressure because of sexual orientation?
    We're not NordVPN here. The only thing I can throw in here is that there is no Netgear RAX1 model - the suffix -100NAS is the designation of the hardware (100) version and NAS indicates its a device for the North American market.
  • plemans's avatar
    Most of these vpn's you either install to your router or all your devices.
    If you want to install it to your router, it has to be a compatible one. that router isn't compatible.
    so you'd either need to install nord to each device individually or buy a router that is compatible.
    Check nord's site for compatible routers as its third party firmware and not supported on official forums.
