Orbi WiFi 7 RBE973
Reply
RAX120 SSH access
BioRAX120
Tutor
RAX120 SSH access
Hi all, I have a RAX120v1 with last firmware installed ( v1.2.9.52 )
I was able to enable the telnet port so I can logn into the router via telnet terminal on port 23
My question is:  being connected into the router via telnet do someone know which linux command I can use to enable the port 22 SSH connection?
I don't even know if an ssh server is active / running on the RAX120 so it's just a matter to somehow enable the firewall to let me use the SSH on port 22 or instead is not possible?
Message 1 of 10
Guru
Re: RAX120 SSH access
Most likely not possible. SSH may required special keys that are not made public for security reasons.
Message 2 of 10
BioRAX120
Tutor
Hi and thanks for your reply.
well, I am a beginner so I don't have experience and knowhow, but reading several article on the web I see
someone did it on other netgear router, maybe having Dropbear SSH installed as server..?
Do you know if this would be possible, or any other ways
Message 3 of 10
Guru
What other NG router model was this?
NG removed Telnet access support from most of there newer versions of FW. Though I presume one may have found alternative means to enable telnet access.
Message 4 of 10
BioRAX120
Tutor
I was able to enable telnet on my RAX120 with very last firmware running.
my problem is now, how can I activate the SSH ?
Is SSH just blocked by firewall? in case which telnet comand I can use to check, verify or evenatually unlock SSH?
Or if SSH server is not there, can I install example dropbear - lightweight SSH2 server
or any other OpenSSH?
Message 5 of 10
Guru
What NG router that was mentioned being able to use SSH?
Most likely no.
Message 6 of 10
BioRAX120
Tutor
there are, but running modded firmware...example the one voxel created.
Message 7 of 10
Guru
Ah ok, that would be why then. You'll not get SSH access with NG Stock FW.
Message 8 of 10
BioRAX120
Tutor
So on original last firmware, having telnet access, there is nothing we can do to try to unlock SSH by telnet command, maybe installing a ssh sever openssh, or something similar? Changing firewall permission from telnet? Adding things via telnet? As said I'm not familiar with Linux I just would like comment from developers that maybe let me do some test?
Message 9 of 10
Guru
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1104 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
