cjmiller1994
Aug 21, 2022Follower
RAX120 WAN Aggregation vs. MultiGig Port
I recently bought an RAX120 and CM1100 Modem.
Both are capable of WAN aggregation. The RAX120 also has a MultiGig Port.
My question - is the WAN aggregation typically better than using the MultiGig Port?
Or, are they not mutually exclusive?
1 Reply
Since the CM only supports 1Gb connection rated speeds. You might give LAG on the CM and RAX a try.
