bosyotech
Mar 12, 2022Aspirant
RAX200 Can't connect to 5ghz-1
Hi,
I have an RAX200, Firmware Version V1.0.5.132_1.0.69.
I have setup the access points separately with different SSIDs.
I'm having trouble with the 5ghz-1 where no devices can either connect OR can connect but no internet at all. 2.5 and 5ghz-2 works fine. The ssid can be seen but just don't work.
Could this be a firmware issue? Is there a way to downgrade?
Thanks
- Razor512Prodigy
Which channels is the 5GHz 1 radio using? While less common unless you are using older devices, if it is using DFS channels, some devices may not be able to see them, especially older devices.
Different regions have different sets of DFS channels. https://en.wikipedia.org/wiki/List_of_WLAN_channels#5_GHz_(802.11a/h/j/n/ac/ax)
