billdavies
Jul 31, 2022Star
RAX80 firmware update failed due to GUI update
I seem to be having some version of this issue. I am hard-wired to a 10/100/1000 switch and getting to the router that way. It is not easily accessible to where I sit. No issues getting to it, either with the app or with browser. I've tried both ways.
It has been set to update automatically. Apparently it's not. When I try to do this by clicking "update now" it just tells me to wait and never updates.
Tried a few minutes ago with the app which told me to wait 2 minutes. 5 minutes later nothing had happened.
| Current GUI Language Version: | 1.0.6.138_2.1.46.1 |
| New GUI Language Version: | 1.0.10.140_2.1.46.1 |
| Current Firmware Version | 1.0.6.138 |
| New Firmware Version | 1.0.10.140_1.0.79 |
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Perform a manual FW update using a wired PC and web browser by downloading the FW file as outlined here:
I would then factory reset the router and setup from scratch with out a prior backup configuration after the FW has been applied.
Makes me long for the days when Apple laptops had ethernet ports. 😕
Just add a USB to Ethernet adapter to the mac book. I use them on mine.
Hi billdavies
Please try again clicking "update now", it should work now, thanks.
- iyangNETGEAR Expert
Until yesterday. Someone read my post and now the router is able to update!
So it updated successfully then?
