× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAXE500 - Can I use VLAN tagging to isolate one physical port?
JohnInAtlanta
Follower
I am using an RAXE500 as the centerpiece of a home network.  Is it possible to configure this router (VLAN?) to isolate one of the physical Ethernet ports from the rest of the network but allow it to continue to connect out to the internet?
My wife has a home office and wants to connect an unmanaged switch to the (home) network.  I would like to give her a connection that is isolated from all WiFi traffic as well as traffic on the other wired Ethernet ports but still allow her access out through the Multi-Gig port to the cable modem.
Please/thank you for any input.
Message 1 of 2
Accepted Solutions
Guru
Re: RAXE500 - Can I use VLAN tagging to isolate one physical port?
I believe VLAN tagging is for ISP services only from the WAN side. Router doesn't have any VLAN tagging support on the LAN side. Thats mostly seen on managed LAN Switches.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 276 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
