Dfb1's avatar
Dfb1
Initiate
Aug 13, 2021
Rax200 internet led - red
After power outtage (i had to install a lamp) my internet does not work.
On the router the internet led is red and this color is not mentioned in the manual.
I waited 2 days and it was still red. Rebooted and it is still red.
  • what modem/gateway is it connected to?
    have you powered off the modem and router?
    then power on the modem first and give it a couple minutes,
    then power on the router and give it a couple minutes.
  • plemans's avatar
    • Dfb1's avatar
      Dfb1
      Initiate
      Buddy!
      You have No idea how much time you saved me by avoiding a reset.
      I really hope Netgear adds your fix to their manual.
      Have the a super weekend, ya legend!
