- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Speed Test
- Mark as New
- Bookmark
- Subscribe
- Permalink
Speed Test
Our community has gotten fiber service and got 1 Gbps service with our ISP.
I'm using:
NETGEAR Nighthawk AX8 WiFi
8-Stream AX5700 WiFi Router
with latest firmware available.
The concern I have is with PS4 connectivity performance. The speed I get on the Ps4 is around 490 Mbps download and 110 Mbps download wired directly to the router using a CAT8 cable.
Running the speed test on the router itself gives me on the average:
Download: 550 Mbps
Upload: 530 Mbps
That's not close to the 1 Gbps expected.
I have run speed tests directly to a laptop and results I got:
Download: > 900 Mbps
Upload: > 500 Mbps
Is there an issue with the router for the speed performance? Any tools should I use to troubleshoot the issues?
Your hep is very much appreciated.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Speed Test
RAX###?
What are your wired speed results with a wired PC connected to the ISP modem? Same at the router?
Use Ooklas installable speed test app on the wired PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Speed Test
RAX75
Firmware: V1.0.6.138
ONT Manufacturer: Nokia
Model: unknown, S/N available externally
Factory reset has not been done. Kindly, provide resource for performing factory reset if recommended
As I have shared in my original post:
Wired PC to ONT connection speed test: > 900 Mbps download & > 500 Mbps upload
Router speed test: Download: around 550 Mbps & Upload: around 500 Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Speed Test
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Always do this when you have changed your Internet service. You want it to forget any settings carries over from the old Internet service.
Also done wired?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Speed Test
Thank you very much for the link.
1- Wired: Router ---> ONT using Cat5 cable provided by ISP and running Netgear's own speed test available through the Netgear Nighthawk iOS APP: Download: around 550 Mbps & Upload: around 500 Mbps
2- Wired: PC ---> Netgear Nighthawk router running speed test in Chrome: Download - 655 Mbps & Upload - 440 Mbps
I will do the factory reset procedure and see if that improves things.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Speed Test
Not the most reliable speedtest. Try few others.
