- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Surfshark VPN with R6400v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Nighthawk R6400v2. I would like to download Surfshark VPN and put it on the router. Surfshark says I should look for OpenVPN Client in the list and not to mix it up with an OpenVPN server. Does anyone know if R6400v2 has OpenVPN Client? I cannot seem to find that this is compatible with R6400v2. Does anyone know if I can download and use Surfshark on R6400v2?
Thanks,
Ron
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Surfshark VPN with R6400v2
for the R6400v2 to support surfshark, you'd need to install 3rd party firmware to it. It doesn't from stock.
From there you could use it.
Be aware, installing 3rd party firmware to it will void your warranty and can brick your device if done wrong.
Should you choose to go that route, google your model number and ddwrt
https://support.surfshark.com/hc/en-us/articles/360003103833-How-to-set-up-a-router-with-Surfshark-
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. I'm hesitant to monkey around with it too much. Is there a reasonably priced VPN that you would recommend, that I can put on an R6400v2?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
Thanks,
Ron
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
The only vpn that works on stock firmware is the built in one.
If you're wanting a different one, you'd have to install the 3rd party firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I am not mistaken, the built in one will allow me to securely access my home computer when I am out traveling. Does the built in one allow me privacy in regards to my activity on the internet? I'm trying to take some steps to increase my level of privacy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you're looking for the easiest to use/secure, I'd look at installing the 3rd party firmware and using a vpn that hosts in a country that doesn't allow monitoring/logs.
