× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
VPN Config On Rax80
Milk_Money
Follower
VPN Config On Rax80
Im setting up VPN configuration on my router. I downloaded and configured the sofware. Changed the connection name and not able to connect. The default ports are 12973 on "TUN and 12974 on "TAP" when i check to see if my port is open on https://www.canyouseeme.org/ theyre closed. I'll call my ISP to open them but not sure if that is the only reason why im failing to connect? Or if thats even the issue?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: VPN Config On Rax80
Hi Milk_Money,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 789 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
