× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WAN and LAN LAG at the same time
Retired_Member
Not applicable
I have the RAX120 and have a NAS that I am using LAG on LAN ports 1 and 2.  This is working great but would like to know if I can use WAS LAG as well.  I know there is the WAN port and the 2.5Gb port.
In the documentation it stats WAN LAG uses the internet (WAN) port and one LAN.  If ports 1 and 2 are used by the LAN LAG for my NAS,  What ports would I use for the WAN LAG?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 5
Accepted Solutions
Christian_R
NETGEAR Employee Retired
Re: WAN and LAN LAG at the same time
shamelin73 - The RAX120 currently does not support WAN & LAN aggregate at the same time.
~Christian
Message 3 of 5
All Replies
Retired_Member
Not applicable
Is there any clear information on this? Or a diagram showing the connections.
I know like the other brand with an A uses the WAN and LAN port 4 for WAN LAG and LAN ports 1 and 2 for LAN LAG.
The wording on the RAX 120 is a bit vague.
Message 2 of 5
Christian_R
~Christian
Message 3 of 5
Retired_Member
Not applicable
I am supprised that this is not supported.  The AX8 does and other brand AX routers do.  Could it be that this would be a future add via the firmware?
Message 4 of 5
Christian_R
shamelin73 - If you'd like to to see this feature added via firmware, we recommend posting this idea on our idea exchange board.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
~Christian
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1989 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
