KangHH12
Nov 28, 2022Aspirant
Why Netgear disabled Wpa2/Wpa3 mixed mode on Rax38v2?
Wpa2/Wpa3 mixed mode disappeared on my Netgear Rax38v2
firmware is latest.. V1.0.11.112_2.0.77
It was available on Rax40v1 but in Rax38v2 It disppear
I wonder if there is a plan to support it through an update in the future
Possible that NG hasn't implemented this on this model router yet.
There a picture of this?
Did you factory reset and setup from scratch to be sure after you updated FW?
What do you see if you downgrade the FW on the RAX38 router?
- KangHH12AspirantI've never downgraded so I don't know what I'm seeing
After receiving the router, it was already the latest firmware, and it was initialized and set up
Which picture do you need?- FURRYe38Guru - Experienced User
One from the Basic tab/Wireless settings showing the security modes available...
