× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
setup of nighthawk ac1900 behind Att uverse router
gbridgeman
Follower
My router provided  by ATT has too many devices attached so I bought the Nighthawk since users said is can go behind the primary ATT router.
I cannot connect to the new router. There are no directions with the router so I'm stuck.
Thanks
Model: C7100V-1AZNAS|Nighthawk AC1900 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: setup of nighthawk ac1900 behind Att uverse router
A couple things.
1. you put nighthawk router but your signature lists the C7100v which is cable modem/router.
2. You put that you have att with a att router. running 2 routers on a network puts you in a double nat. You can get around this by placing the att in pass through/modem only or a regular router in AP (access point mode). But that option isn't availble if you have the C7100V.
https://kb.netgear.com/30186/What-is-Double-NAT
So what actual router did you buy?
You can go to netgear.com/support/   type in your actual model number and it has install videos, install instructions, manuals, and firmware.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 991 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
