FURRYe38's avatar
New - RS700S Firmware Version 1.0.7.80 Released
Enhancements: 11/21/2023
  • Removes Korea/Japan/Singapore/India on supported country list.
  • Stability enhancement.
  • Galaxy Z Fold4 IOT performance enhancement.
  • DFS mechanism enhancement.
Bug Fixes:
  • Fixes case of NAT loopback.
  • Fixes case of setup loop over GUI via WiFi.
  • Fixes case of USB drive detection.
  • Fixes case of no LinkRate and Connection type information for clients on NH APP.
Security Fixes:
Download Link: https://www.netgear.com/support/product/rs700s
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a >factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here:
This article applies to:
Let us know how it works for you...
  • Hi I just got this Netgear RS700 and had no issues with DoS attacks
    untill 2 days ago when there was a firmware update Firmware Version V1.0.7.80_2.0.79
    Small network like 15 total PCs and devices in private home where most times maybe half of these are on so router is mostly idle
    As soon as this was updated these DoS attacks began and never stop
    I tried blocking UDP services for ports like 4-19 but that did nothing at all to stop this
    What is this sudden cause and how to correct ?
    Thanks for the help.  JR
    Small example:
    [DoS attack: RST Scan] from source 54.197.98.98,port 443 Thursday, Nov 30, 2023 20:18:56
    [DHCP IP: (192.168.1.9)] to MAC address AC:E0:10:4E:60:DE, Thursday, Nov 30, 2023 20:17:26
    [DoS attack: snmpQueryDrop] from source 147.203.255.20,port 58342 Thursday, Nov 30, 2023 19:57:05
    [DoS attack: Fraggle Attack] from source 10.9.144.1,port 67 Thursday, Nov 30, 2023 19:55:12
    [DoS attack: Fraggle Attack] from source 10.9.144.1,port 67 Thursday, Nov 30, 2023 19:54:57
    [DoS attack: Fraggle Attack] from source 10.9.144.1,port 67 Thursday, Nov 30, 2023 19:54:55
    [DoS attack: RST Scan] from source 95.100.155.249,port 443 Thursday, Nov 30, 2023 19:46:19
    [DoS attack: RST Scan] from source 95.100.155.249,port 443 Thursday, Nov 30, 2023 19:34:19
    [DHCP IP: (192.168.1.9)] to MAC address AC:E0:10:4E:60:DE, Thursday, Nov 30, 2023 19:26:11
    • ShadowMario3's avatar
      ShadowMario3
      Luminary
      I have the same issue with DoS attacks appearing in the logs even few seconds. From what support told me, it seems they are false positives. For now, I have disabled "Known DoS attacks and Port Scans" under "Include in Log" so it won't overflow the log:
      Luckily, it doesn't seem to interfere with my port forwarding or internet speed.
      • TeamCorvette's avatar
        TeamCorvette
        Tutor
        Thanks for the quick reply
        What they are saying is hide the fact in logs that this new firmware is not blocking DoS at a high rate per second, so really masking the problem and not knowing if those attacks are affecting the PCs and devices on my network
        As it is these are coming from many different TCP/IP addresses
        Did they say they are working on a fix and when that will happen
        As I mentioned none of these occured with last firmware version
        Thanks again . . JR
