FURRYe38's avatar
New - RS700S Firmware Version 1.0.7.82 Released
New changes: 12/22/2023
  • Android 14 clients IoT behavior enhancement.
  • CBP mechanism enhancement.
  • 5G ACS mechanism enhancement.
Bug Fixes:
  • Fixes case of new SSID change doesn't take effect.
  • Other bug fixes.
Security Fixes:
Download Link: https://www.netgear.com/support/product/rs700s
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a >factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here:
This article applies to:
Let us know how it works for you...
  • Unfortunately, this firmware still has the issue with the false positive DoS attacks filling up the logs. Will hang on to the old firmware until this gets fixed.
    • FURRYe38's avatar
      What happens if you disable the logging feature for DDoS attackes while v.82 FW is loaded?
      Also how was the FW updated and did you continue to use the router after FW was applied, powered OFF the router for 1 minute then back ON or had a factory reset been performed afterwards then setup from scratch?
      BH_C
      • ShadowMario3's avatar
        ShadowMario3
        Luminary
        Even when I had logging for DoS attacks disabled, it would still take up resources. Only reason I noticed this was because I noticed that the router was slowing down/crashed by the end of the week. Also, if you turned logging back on, all the previous false positive DoS attack logs would appear right away and crash access to the log itself due to so many entries appearing there.
  •  installed and rebooted router yesterday 12/25/23 Monday
    Turned back on in logs for logging Dos Attacks and again with this newest version still occurs
    Just cleared log and DoS frames entering router
    • FURRYe38's avatar
      And if you disabling logging, do you still see DDoS log enteries or no?
      If you disable the logging for DDoS, do you notice any router mis-behaviors with logging disabled?
      Also that IP address shows it's from Amazon:
      Organization: Amazon Technologies Inc. (AT-88-Z)
      RegDate: 2016-08-09
      Updated: 2016-08-09
      Ref: https://rdap.arin.net/registry/ip/35.152.0.0
