nickashfield
May 23, 2020Initiate
DHCP Option 61 (Client ID)
After four frustrating hours on the phone with Netgear's awful technical support, they finally confirmed that the Orbi does NOT currenty support DHCP Client Identifier String (Option 61) in order to authenticate with "Sky" - my UK ISP. As a consequence I was unable to access the internet with my modem (D6400) in modem mode. Yes I understand that I can use the RBK853 as an Access Point but this defeats the object of purchasing such an expensive Router. I want to be able to use all functionality. If I don't put the modem in modem mode, then I have the problem of double NAT.
It is possible to use your own hardware with Sky's Fibre Broadband service providing that the router is able to send DHCP Client Identifier String (Option 61) requests to the ISP.
My Netgear D6400 modem supports DHCP Option 61 but to my amazement NOT the latest Netgear Orbi products. I don't understand why the Orbi lacks this basic firmware functionality. This is so annoying and frustrating considering how expensive the RBK853 is. As a consequence I have had to return the product for a full refund since it is not compatible with Sky broadband.
Please please please Netgear would you issue an urgent firmware update that supports Option 61 functionality to ALL Orbi products. Thank you.
Please most about this request here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Thank you.
- nickashfieldInitiate
Many thanks. I have accepted your suggestion and now posted as an idea improvement.
Good Luck.
- Daniel-UKApprentice
nickashfield on my Orbi RBK53 on Basic --> Internet I can see there are DHCP settings for both Option 60 and Option 61 (see the bottom of the picture below).
I am not sure this is appeared with a recent firmware update but in any case NONE has been able to advise on how to configure the settings below for the Orbi to work as the PRIMARY router with Sky Broadband :-(
