Discussion stats
  • 10 replies
  • 1981 views
  • 3 kudos
  • 7 in conversation
Announcements
Top Contributors
Reply
Highlighted
Apprentice
Mounting Bracket
So I had to install the RBR850 on the wall. The screw holes on the bottom were perfect. I had to run to Lowes for 2 L bracket looks like garbage but it works. I wonder if Netgear has or had plans for a bracket.
Message 1 of 11
Highlighted
Luminary
Re: Mounting Bracket
There are several aftermarket wall brackets for the Orbi's on Amazon.
Message 2 of 11
Highlighted
Apprentice
Yes for the 1st gen I order them all the time cause I actually install them for a living. But gen 2 AX I haven seen any yet
Message 3 of 11
Highlighted
Master
I used the old Orbi RBK50 wall mounting brackets to mount the Orbi AX units. Picture attached
The Orbi AX units are a bit bigger in size, but with some "fillers" I managed to re-use the brackets until a kit is available for the new Orbi AX. Smiley Happy hopefully soon!
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 4 of 11
Highlighted
Apprentice
Message 5 of 11
Highlighted
Looks great! Thanks for sharing
Message 6 of 11
Highlighted
Tutor
Is this the mount in the picture?Koroao Wall Mount Holder for Orbi Home WiFi
Message 7 of 11
Highlighted
Master
Yes, this is the one in the picture in my previous post.
Message 8 of 11
Highlighted
Master
Is it correct to assume that you fished the low voltage part of the power cord down and out of the wall?
I love my Orbi.
Message 9 of 11
Highlighted
Master
Correct!
Message 10 of 11
Highlighted
Guide
Re: Mounting Bracket for AX6000
Try this link:
https://www.amazon.com/Bracket-Holder-Tri-Band-TIUIHU-Compatible/dp/B083W3RQC5/ref=sr_1_3?keywords=W...
These work very well and are designed for the new Orbi RBR 850 Router and Satellites.
Message 11 of 11
