powersj1980's avatar
powersj1980
Follower
Feb 02, 2021
OfficeJet 9025e Will not connect to Mesh Network....Help!
I currently have an RBS750 Mesh router and HP told me that my OfficeJet 9025e printer would not connect to a Mesh Network.  Were they right or can I make this work somehow?  Please Help!
  • FURRYe38's avatar
    Please contact the mfr of this printer for help and informatiion regarding there product. Review the installation guides and user manuals for the printer. Be sure the printers FW is up to date.
    Use it's LAN port to connect to the Orbi system.
    HP told you a falsely.
    If the printer was recently setup on another wireless system, I suggest resetting the printer, then using the printer panel, reconfigure the printer to connect to your Orbi mesh system.
    1. From the printer control panel, touch or swipe down the tab at the top of the screen to open the
    Dashboard, and then touch (Wireless).
    2. Touch (Settings).
    3. Touch Wireless Settings.
    4. Touch Wireless Setup Wizard or Wi-Fi Protected Setup.
    5. Follow the display instructions to complete the setup.
