kleek1975's avatar
Aug 08, 2020
Orbi WiFi 6 System (RBK853) AX6000 with Outdoor Mesh Point
I currently deploy Netgear Insight managed switches on my home network.  I really like Insight App.  I'm wanting to upgrade my Amplifi HD wifi system with a Orbi WiFi 6 System (RBK853) AX6000.  My home has fiber and 1000 MB upload/dowload speed.  I have a large backyard with a pool and other ammenities (not to mention lots of outdoor devices that need good wifi).  I don't want an extender as I move back and forth from the indoor and outdoor areas of my home regularly.  Does Netgear make a Mesh Point for outdoors that is compatible with the Orbi WiFi 6 System (RBK853) AX6000?  Not an extender, but a true mesh point.
  • CrimpOn's avatar
    CrimpOn
    This question will probably get a more informed response if posted in the community forum devoted to the AX product line:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    While there may be one or two people who are active in the "regular Orbi" forum who also own an AX system, the vast majority of us are here because our product is the original WiFi5 residential Orbi.
    In my opinion, you are wise to settle this issue before committing to a product.
    • kleek1975's avatar
      kleek1975
      Guide
      Thanks for the recomendation.  I reposted as you suggested!
      • Orbi220's avatar
        Orbi220
        Did you get the answer? I am in same situation. Please share.
  • FURRYe38's avatar
    Any progress on this?
