bojackkk
Mar 15, 2020Aspirant
RBK 852(wifi6 ) wifi download speed only 100Mbps under Gigabit internet
Seems Netgrar community doesn't even have this modle when create the discusstion.....
Buy from Amazon https://www.amazon.com/gp/product/B07WNY2WKG/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
Wave Gigabit internet in home. Speedtest inside Orbi App shows 920Mbps/930Mbps which is good enough for gigabits.
Issue is wireless speed only 1/9 of the gigabit speed:
- iPhone 11 Pro Max Wifi connected to the router, speedtest download speed only 100Mbps.
- Macbook Pro 13-inch 2017 Wifi connected to Satellite, speed test around 100-200Mbps, rarely 200.
Wired:
- Upload speed is almost 300-600 Mbps in above situation.
All config is auto like channel etc. What's wrong with this wireless speed. I'm thinking to see at lease 300 to 600 Mbps? (I've have ASUS in China, with 1000Mbps internet and my 11 pro max is getting 700 to 900Mbps speed of download.)
Model and firmware version:
Model Name Device Name Current Firmware Version Status
What is the Mfr and model# of the ISP modem the NG router is connected too?- bojackkkAspirant
https://www.whoismyisp.org/ said my ISP is vanoppen.biz LLC.
I'm using WaveG.
How to check model# and what is Mfr? The technition come to home and did some on wall. all network seem to configure in the wall.
- renekyTutor
I seem to have the same problem: my brand new RBK 852/AX6000 connects to my router at 100MB
My router is a Mikrotek RB2011UAS running RouterOS v6.46.4 (latest version).
I connect the RBK852 to one of the ethernet ports on the Mikrotek RB2011UAS, and then see this on the Mikrotek:
/interface ethernet monitor ether4
status: link-ok
auto-negotiation: done
rate: 100Mbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
advertising: 10M-half,10M-full,100M-half,100M-full
link-partner-advertising: 10M-half,10M-full,100M-half,100M-fullSee especially that last line: link-partner-advertising, which caps out at 100M-full.
The other ports have other things connected, and say:
rate: 1Gbps
If I swap ports I also get swapped results, so it really seems like the RBK852 is only advertising 100MB.
I updated the firmware when setting it up, and it now says there is no more updates.
I used the ethernet cable in the RBK852 box to connect the RBK852 to the Mikrotek RB2011UAS.
Any idea how I can get the RBK 852 to use 1Gbs to connect to the modem/router ?
Update: I connected my old AP, a Apple Airport Extreme, and it gets the 1 Gbs rate.
Swap LAN cables out for a good quality CAT6 cable.
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Is the microtik the router in front of the RBR or is it the modem as well?
If you have a router in front of the RBR and remove it and connect the RBR directly to the modem.
Be sure your connecting the RBRs yellow WAN port the GB ports on your router. I see your router has both GB and 100Mb ports.IF the same thing happens and a reset on the RBR fails as well, take the Orbi AX system back and get another. I would presume the WAN port on the RBR is faulty. It should connect at 1000Mbps.
reneky wrote:I seem to have the same problem: my brand new RBK 852/AX6000 connects to my router at 100MB
status: link-ok
rate: 100Mbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
rate: 1Gbps
Load up WiFi Sweet Spots on your iPhone then turn OFF The RBS. Connect the iPhone to the RBR and see what speeds the iPhone is connected at with the RBR. iPhone should be around 3 to 6 feet from the RBR.
- bojackkkAspirant
Not much different. I test several times over several hours.
iPhone 11 Pro Max Wifi connected to the router, no Satellite on.
Download at most can be 200Mbps, just two times. And all other is still fall in 100Mbps.
- Upload speed is still almost 300-600 Mbps in above situation.
Even 200Mbps compare to 1000Mbps is 80% loss, that's terrible, I'm thinking about 400-600Mbps
