WakaWaka22's avatar
WakaWaka22
RBR750 Slow Upload Speed
Please help!!
For whatever reason within the last week, I have lost all of my upload speed.  Prior to this taking place, I was consistenly receiving more than 50mbps and recently it has been ranging between 0.05 and 2.5 mbps.  My download speed has been excellent and consistently topping out north of 500 mbps.  I have done multiple resets on both my modem and router with no luck.  Both my wife and I work from home and this is only going to get worse. Details below on what I am using.
Yesterday I did a manual update on the app for FW v.3.2.16.22 and for whatever reason the speedtest on the app is not showing a connecting either.  Upon calling Wow, they indicated that the numbers looked good on their end and that because I have my own router, there is nothing they could test against.  What a mess.  Be kind, I am somewhat of a novice here.
Internet:  Wow 1GB Plan
My Orbi is currently at firmware 3.2.16.22
Modem - Arris Surfboard SB8200
Manual channel setting is 1 on 2.4 Ghz
WPA2-PSK (AES) Security
  • Thank you!!  Def was the firmware that needed to be updated.  Ran a speed test and obtained 768 down and 35 up.
    • FURRYe38's avatar
      What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
      • WakaWaka22's avatar
        WakaWaka22
        Thank you for the feedback.  Will do the manual download and share back the results.
        Our home is ~3,200 sq ft and the they are as close to 30ft apart as possible.  Up until this past week, I have never had issues to date on the download / upload speed
