Eric_In_FL's avatar
Eric_In_FL
RBR750 Zoom Audio and Amazon Streaming issues
Recently purchased and installed an RBK752 system - 1 RBR750 router and 1RBS750 Satellite. Both are running Firmware v3.2.16.6_1.4.4. I've got 2 issues - possibly (not sure) both related.
Issue #1: When connected to a Zoom call through a wired or wireless connection, my outbound audio isn't working. Video is working fine, inbound audio is fine, but outbound audio is not working at all. I can hear everyone else perfectly, but they can't hear me at all. Also tried with a Bluejeans (less popular video conference software) call and had the same issue. (If I connect through my employer's VPN, no issues) (Also, there were no issues before installing the Orbi.)
Issue #2: My wife is having trouble streaming Amazon Prime video on her ipad and iphone. The video will start to load, will buffer for a while, and may play a few seconds, but isn't really watchable. I tried on an android tablet, and was able to get the stream to work, but there was a lot of video degradation.
My ISP is AT&T UVerse, using an Arris 5268AC gateway. The Orbi is in Router mode, and is set up as a DMZ+ device on the gateway. (Yes, I know, this means that I'm double natted, but I thought the DMZ+ mode would mitigate that.) I have done a factory reset on the Orbi Router after installing the firmware, and I configured it without enabling/activating Armor.
Any suggestions?
  • FURRYe38's avatar
    Be sure the ISP modems wifi radios are fully disabled.
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only, uncheck the box. Set Short preamble instead of Long preamble modes. Set CTS to 2347. Save settings and reboot the router and satellite(s).
    You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
    Try the RBR in AP mode. Disable DMZ+ on the modem if you try this.
    • Eric_In_FL's avatar
      Eric_In_FL
      • House is 3000 sqft. Router and satellite are wirelessly connected, roughly 45 linear feet apart, and 10 vertical feet (router is upstairs, satellite is downstairs). Interior construction is wood frame/drywall
      • Armor is disabled
      • ISP Modem Wifi is disabled (both 2.4ghz and 5ghz)
      • IPv6 is disabled on the Orbi. Should that also be disabled on the ISP device?
      • Updated the preamble, CTS, and coexistance settings as described
      Still encountering the issue with the video quality on Amazon Prime, haven't had a chance to test a zoom call yet. I'll check that tomorrow and update again.
      • FURRYe38's avatar
        Try streaming with just the RBR only. Turn OFF the RBS...as a test.
