- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
add third satellite to RBR850
- Mark as New
- Bookmark
- Subscribe
- Permalink
My current setup is RBR850 router with two RBS850 satellites, one wireless and the other ethernet. I want to add a third satellite via ethernet but the port currently is wired to a desktop. Is a solution a splitter (or switch or some other device) from the port to the desktop and new satellte. What make and model would best be suited? The input wifi signal is 490 mbps
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok so you have a wall LAN jack that comes from the down stairs RBR correct?
If so, then you can place a RBS at this location and connect the wall jack to the RBS here. Then use the free additional ports on the back of the RBS to connect other wired devices to the RBS...
Or you can place a Gb LAN switch as this wall jack and then connect the PC and RBS to this all jack.
https://www.downloads.netgear.com/files/GDC/datasheet/en/GS105v3-GS108v3.pdf
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: add third satellite to RBR850
"I want to add a third satellite via ethernet but the port currently is wired to a desktop." What port are you referring too?
- Mark as New
- Bookmark
- Subscribe
- Permalink
THe proposed location of the new satellite is an upstairs room with an ethernet plug (rather than port) hardwired from the downstairs Orbi router. That plug in turn is currently hardwired to the desktop that I want to retain. I want to hardwire the new satellite from that same plug. Hence the need for two lines via a splitter, switch or some other device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
