JamesENicholson's avatar
Jan 13, 2024
Ethernet Backhaul is freezing up
I actually have the exact same problems with my SXR80 and (5) SXS80 satellites. I bought all the satellite to essentially act as remote switches with wifi satellite capability. The wired backhaul has constant problem. With Tivo units I get constant dropped frames and lost connections. I will completely lose satellites on occasion and have to disconnect and take it to the router and hard-wire reset it by connected directly to the router and after a few hours take it back to its location. It is a **bleep**ty system without doubt.
It is actually more stable using WiFi backhaul and not using the ethernet backhaul but this eliminates my purpose of using each satellite as a "remote" switch to plug in each TV/Tivo/AppleTV/Playstation/etc hard wired.
  • CrimpOn's avatar
    CrimpOn
    If the system is more stable when using WiFi backhaul, the devices still can be wired to the satellites?  Ethernet backhaul is a feature, not a requirement.
    • JamesENicholson's avatar
      JamesENicholson
      Ethernet backhaul may be a "feature", but it was an expectation and a requirement for how I planned to connect my 6,000 sqft home. I did not want to rely on WiFi backhaul and instead wanted the redundancy of both WiFi backhaul AND ethernet backhaul. I did not want to buy 5-port switches at every location and was willing to invest in satellites that had 2.5Gbe ethernet backhaul with 4 free ethernet ports to essentially act like a remote switch. If it was included by the manufacturer, IT SHOULD WORK!
      • CrimpOn's avatar
        CrimpOn
        Agree entirely.  Wired backhaul should work.
        This package is a bit of a puzzle (first time I have looked at the Product Data sheet)
        https://www.downloads.netgear.com/files/GDC/SXK80/SXK80_DS.pdf
        The router has one 2.5G port which must be used as the WAN connection, plus (4) gigabit ports.  Thus, satellites can be connected at a maximum of 1gigabit. (unless gigabit ports 1&2 are aggregated into a suitable switch).  Each of the satellites has a 2.5G port plus that weird pair of port 1&2 that can be aggregated and ports 3&4 that are simple gigabit.
        The problem description does  not mention any switches in the configuration.  Is it correct to conclude that the satellites are connected directly to the router?  Which ports are being used?
        Has the 90 days of 'complimentary support' expired on this purchase?  (I would love to hear what Netgear support says about wired backhaul not working.)
      JamesENicholson
      My SRK80 system has the exact same problems. I can use the satellites with ethernet backhaul IF no devices are connected to each satellite OR I can use the satellites as switches IF wired backhaul is disconnected. Otherwise at some point today, tomorrow or 2 weeks from now one or more of the satellites seems to get confused and cannot maintain connection and starts rebooting continuously and occasionally crashes the entire network.
      Basically it is a POS.
      I was hoping to use each of my satellite as remote switches with ethernet AND wireless backhaul as needed, but these system is just too unstable.
      It is super annoying.
ProSupport for Business
