Orbi WiFi 7 RBE973
New - SXR30 / SXS30 Firmware Version 4.2.0.122 Released
Guru
New Features: 03/31/2022
  • Supports WPA2/WPA3-mixed mode in wireless networks 1 - 3
  • Supports OWE in the guest portal
  • Supports WPA2-PSK modes in the guest portal
  • Supports WiFi scheduling
  • Adds more satellite information in the satellite’s device UI
  • Supports IPTV
  • Supports Insight Business VPN for wired clients connected over LAN ports
Bug Fixes:
  • Fixes an issue where the NTP server can be blocked by ISPs in the U.S.
  • Fixes a configuration conflict between Insight and Standalone settings
  • Fixes an issue that can prevent the guest portal from displaying
Security Fixes:
Known Issues:
  • After updating the router firmware, existing clients can be steered to the router because the wireless readiness in the router is faster than the wireless readiness in the satellite.
    Workaround: Connected clients might notice slower throughput or a weaker signal, which resolves when the user roams or reconnects.
  • WPA3-Enterprise might not work with iPhone 11 (supports 802.11ax) and above on iOS 14 and above.
    Workaround: Do not use WPA3-Enterprise.
  •  The device UI can be accessed via the default VLAN network only.
    Workaround: Connect to a WiFi network that uses the default VLAN profile when you want to access the device UI.
  • When the SXR80 router is connected to multiple SXS30 and SXS80 satellites, it is possible that the SXS30 satellite cannot ping the SXR80 router, and the bar LED lights magenta. However, clients can still access the SXS30 satellite and the Internet.
    Workaround: Reboot the SXS30 satellite and the SXR80 router.
  • When the SXR80 router is connected to multiple SXS30 and SXS80 satellites, wireless clients that connect to wireless network 3 with the VLAN feature enabled cannot access the Internet.
    Workaround: Reload the wireless configuration or disable the VLAN feature on wireless network 3.
Download Link:
https://www.netgear.com/support/product/sxk30.aspx#download
Firmware Update Instructions:
If the Orbi Pro WiFi 6 Mini devices are connected to the Insight cloud, perform firmware updates automatically through the firmware schedule policy, or manually perform a firmware update using the Insight app or device UI.
To update Orbi Pro WiFi 6 Mini router or satellite firmware from the device UI, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/
then enter your model number in the search box, and click Documentation on the product page. We highly recommend updating the SXS30 satellite firmware first and then updating the SXR30 router firmware.
After updating to the latest firmware, make sure to update your version of the NETGEAR Insight app for the best functionality and user experience.
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 2059 views
  • 1 kudo
  • 1 in conversation
Announcements
