Orbi WiFi 7 RBE973
Reply
Cannot get Chromecast to connect to Orbi AX1800
Jay-Reddings
I just purchased chromecast but cannot get it to sustain a connection to my wifi. My chromecast connects to the wifi during the setup process but instantly disconnects after the setup is complete. I have an Orbi AX1800 Wifi 6 Dual-Band Mesh Router. The chromecast works in my living room tv and only sometimes loses connection but will not connect to the wifi in the room I want it to be in (this room also has my router in it so it is 100% in range). Any help will be greatly appreciated Smiley Happy
I am on firmware version V4.4.0.10_2.10.63
Message 1 of 8
Guru
Re: Cannot get Chromecast to connect to Orbi AX1800
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try turning off AX for 2.4Ghz on the RBR under basic tab/wireless settings.
Message 2 of 8
Jay-Reddings
My sataliette is around 35 feet away and after turning off AX for 2.4ghz I am still having the same issue. I have read only that changing RIP Version to Rip_1 will help is this true?
Message 3 of 8
Guru
You can certainly give that a try. If it doesn't work you can put the change back.
Message 4 of 8
Jay-Reddings
I tried it and no luck. Any other suggestions, that fact that it connects fine in another room is the thing that is stopping me from returning the chromecast. After making these changes am I supposed to restart my orbi system because currently I have not been doing so after making the changes.
Message 5 of 8
Guru
So it connects in the other room?
Do you know which Orbi unit the device is connecting too? RBR or RBS?
Message 6 of 8
Jay-Reddings
When it works its connected to the satellite. It is in the same room as the satellite when it works but when in the same room as the router it doesn't work.
Message 7 of 8
Guru
So when it's connected the RBS, if you turn OFF the RBS, does it connect to the RBR with out moving this device? IT should connect...
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1514 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
