- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Compatibility of Orbi CBR750 with Orbi RBK852
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would the CBR750 work with my Orbi Mesh System RBK852?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Compatibility of Orbi CBR750 with Orbi RBK852
Who is your ISP?
What is the model# of your current modem?
What ISP speed UP and down do you pay for?
If you have a RBK system already, would recommend a NG CM series modem instead of the CBR. The CBR is a gateway modem and router. It can be used in a modem only mode which could work with the RBK system, however you'll benefit better by having a modem only option to go with your RBK system. The CBR can't be integrated with the RBK system when the CBR is in gateway/router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes the MB8611 can only do about 1Gb.
No idea when the CM3000 will be launched. Could be a ISP only modem as well.
I know the CM2000 and CM2050v are supporting of ISP speeds over 1Gb since they have 2.5Gb WAN ports.
