Orbi WiFi 7 RBE973
Reply
Connecting an ORBI RBRE960 Router to AT&T Fiber with ATT Gateway BGW210-700
Vahri
Follower
#RBRE960
#BGW210-700
#AT&T
Can anyone help me with how to install my fancy new ORBI RBRE960 router? I have ATT fiber ISP with an ATT Gateway BGW210-700. I seem to understand that I have to connect the ORBI directly to the Gateway and convert the Gateway to 'Bridge mode"? I'm not sure how to get there...  Current status is connecting the ORBI to the Gateway does not recognize an internet connection so cant proceed with much at all. Has anyone encountered this problem. ATT tech are not being much help.
You might guess I'm not that good with computers / tech :-)- so idiot proof instructions much appreciated if someone knows how to fix this.
Thanks!
Message 1 of 3
CrimpOn
Guru
Re: Connecting an ORBI RBRE960 Router to AT&T Fiber with ATT Gateway BGW210-700
You have a number of options which depend on how you intend to use the Orbi system.
The most basic is to follow the installation guide:
https://www.downloads.netgear.com/files/GDC/RBRE960/RBRE960_QSG_EN.pdf
Load the Orbi 'app' on a smartphone or tablet.  Open the app and to connect the Yellow Internet port on the router (RBRE960 on the product label) to the AT&T BGW210.
Enabling Armor & Parental Controls is entirely optional.  (I have never done so after noticing "free trial" which implies that these are paid subscriptions.) For myself, I would rather use the Orbi web interface from a computer connected by cable to the Orbi router.  (provides access to options that the Orbi 'app' does not.)  See page 15 of the User Manual:
https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960_RBSE960_UM_EN.pdf
Most customers would choose to disable the WiFi on the AT&T BGW so that there are not two WiFi systems competing with each other.
This basic installation comes with one potential issue: The "Double NAT" created by having two routers in series.  (Check some internet descriptions for information.)  There are specific applications that are affected by a Double NAT, such as using OpenVPN to reach your LAN from the internet, allowing internet access to servers on the LAN, and certain forms of internet gaming.  If these applications are not needed, then you are "good to go."
As you may have noticed, butting the BGW210 in Bridge or Passthrough mode is a complicated issue.  Internet search will turn up dozens of articles on the issue.  If you really need to do this, my guess is someone will offer suggestions.
Message 2 of 3
Guru
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
@Vahri wrote:
#RBRE960
#BGW210-700
#AT&T
Thanks!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1599 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
