Orbi WiFi 7 RBE973
Reply
NEW FIRMWARE RELASED
atiq020
Please can you tell me i just checked my orbi RBKE960 And 2 satellite found new firmware to upgrade last time when i update its causing a issue so after 3 days struggling i manage
NOW again new firwmr arrived at the moment ONE OF MY SATTELE BACKHOUL showing POOR CONNECTION and router and other satellite are GOOD
shall i switch of both satellite and install firmware on the router first and then GOOD SATELLITE on and isnstall
and inthe last poor blackhul  bring closer to router and install
please help before i mess-up  thankyou
Message 1 of 5
Accepted Solutions
Guru
Re: NEW FIRMWARE RELASED
1 yes.
2. yes.
Just be sure to update the RBS first, then RBR lastly.
Message 4 of 5
All Replies
Guru
This is most current:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/New-RBRE960-RBSE960-Firmware-Versio...
What FW version are you using now?
Message 2 of 5
atiq020
i am using Firmware Version
V6.3.7.5_3.2.25
can i do manually update satellites first and then router? i was thinking following step to update please correct me thanks
 1--------- satellite near to router wifi  and attached  SATELLITE WITH eathernet cable  with my laptop and update downloaded desktop saved .img or .chk  imgage and upload.... same procedure to 2nd.. also i already checked my sattelie backhual  is GOOD . is that ok?
2................ORBI router upstairs and i update firmware through web browser and automatic  update is that ok
thanks
Message 3 of 5
Guru
1 yes.
2. yes.
Message 4 of 5
atiq020
Today i try to download latest firmware. just wants to asked Why net gear not fixed this issue not all people are best in computers software. including me we spend £1600 for these 3 and at end we need support to download just a firmware. why its not automatically download satellite first and then router. so please don't mind i asked you final time i am poor in these
1---- please note my satellites  are Not connected with Ethernet cable with router Its ON WIFI and i attached my laptop with Ethernet cable with satellite. download firmware on my desktop and upload .img or chk file only. is that ok
(SATELLITE ON WIFI WITH ROUTER) and satellite attached WIRED Ethernet cable with laptop)
2.............Now Router and my laptop are on WIFI and i upload Automatic way as  when i put user name and password and checked firmware available and just upload automatically is that all
please reply  many thanks
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1114 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
