Orbi WiFi 7 RBE973
Reply
Orbi 6 and upgrade from DSL to Gigabit Fiber
dbcyclist
Follower
I have an Orbi 6 AX4200 Base with 2 Satellites that are hard wired to the base station.
Recently we were able to upgrade from our old DSL connection to Gigabit Fiber.  The fiber terminal  (ONT) is an Adtran SDX611 GPON ONT.
Since the Orbi was originally set up when we had DSL, I'm considering doing a factory reset and setting it up again from scratch.  I think somewhere Ii read that during the setup process, the Orbi analyzes the internet connection and adjusts certain settings, such as for QoS and maybe other parameters.  I'm thinking the whole system may benefit from starting over.
That said, it works pretty well.  My ethernet connected computer is getting 980 Mbps up and down, but my wifi devices are topping out at around 550 up and down.  It's almost like the wifi is throttled.
Any advice if this is a good idea.  I don't remember the setup as being especially difficult.  If I do this, I assume that,  given the ONT terminal mentioned above, the Orbi should be in router mode not AP mode.
Thanks for any suggestions.
Message 1 of 4
Accepted Solutions
CrimpOn
Guru
Re: Orbi 6 and upgrade from DSL to Gigabit Fiber
If it ain't broke, don't "fix it." Yes, the Orbi must be in 'router mode'.
Message 2 of 4
All Replies
CrimpOn
Guru
Message 2 of 4
Guru
Most wifi devices may not see anything near 900Mpbs due to there design and support limiations. Especially 2x2 MIMO devices. 4x4 MIMO can see near that and over. IF your seeing that with your devices and this system, you good.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
Too Much Wifi: https://youtu.be/UR0viMLISz4
Try a power cycle of the system OFF for 1 minute then back on before a factory reset.
Message 3 of 4
Phyber
Luminary
I have the same Orbi router (RBR750) and hardwired satellites (RBS750). I typically get about 600-700 down via WiFi and around 920 down via wired on an 800/20 cable connection. WiFi will always be less than wired due to the nature of WiFi.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 253 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
