fadersnstuff's avatar
fadersnstuff
Orbi 753 and Open VPN - has anyone managed to make this work for a mac laptop??
I've been battling with the VPN server in the orbi for some time now. If I tether my mac laptop to my phone at home in the UK running on data I can connect via tunnelblick. If I'm on an external network I can't connect via tunnelblick. I have checked and the external networks do not share the same 192.168.1.xxx as the orbi network.
I have not been able to connect directly to VPN via Open VPN with either my phone or my iPad as every time I try to open the client.ovpn file downloaded from the "smartphone" button from the router both tell me they 'failed to parse profile: ca.crt, client cut, client.key".
I thought it's ok, I can still tether to my phone and connect to my home network with the mac laptop. I've recently arrived in the US and although I have a data plan and tunnelblick connects on the mac I can no longer access my home network.
Are netgear purposefully making this impossible and providing as little documentation as possible?
If anyone has any help or advice it will be much appreciated.
  • CrimpOn's avatar
    CrimpOn
    Can you please explain "teather".  Does that refer to:
    • Physically connect the laptop to the iPhone, or
    • Create a WiFi Hot Spot on the iPhone and connect the laptop to it?
    On my (old) RBR50, the smart_phone.zip file contains one file named "smart_phone.ovpn". There is no file named "client.ovpn".  Perhaps in their infinite wisdom Netgear decided to rename the ovpn file for the RBR750 series?
    I've attached my smart_phone.ovpn file.  Does your client.ovpn have the same sections as mine?
    client
    dev tun
    proto udp
    remote myDDNSname.mynetgear.com  12973
    resolv-retry infinite
    nobind
    persist-key
    persist-tun
    <ca>
    -----BEGIN CERTIFICATE-----
    VQQGEwJUVzELMAkGA1UECBMCVFcxDzANBgNVBAcTBlRhaXBlaTEQMA4GA1UEChMH
    bmV0Z2VhcjEQMA4GA1UECxMHbmV0Z2VhcjETMBEGA1UEAxMKbmV0Z2VhciBDQTEQ
    MA4GA1UEKRMHRWFzeVJTQTEbMBkGCSqGSIb3DQEJARYMbWFpbEBuZXRnZWFyMB4X
    DTE4MDUyMzIyMjgxMFoXDTM4MDUxODIyMjgxMFowgZMxCzAJBgNVBAYTAlRXMQsw
    CQYDVQQIEwJUVzEPMA0GA1UEBxMGVGFpcGVpMRAwDgYDVQQKEwduZXRnZWFyMRAw
    DgYDVQQLEwduZXRnZWFyMRMwEQYDVQQDEwpuZXRnZWFyIENBMRAwDgYDVQQpEwdF
    YXN5UlNBMRswGQYJKoZIhvcNAQkBFgxtYWlsQG5ldGdlYXIwgZ8wDQYJKoZIhvcN
    AQEBBQADgY0AMIGJAoGBAMhEJZ5zE/JKdEmaPZcYWk8fJSFxdmtVUva5dvv2z02E
    4s21BTsuZM5y9LTW24FHkX6pYEknVLgftb2fmIQ8tH0ln3F/KIGZr4ooSchzpvtn
    X530ztG1zMcV7/y5sWzg2LlU+/zlVzdfMj4lh2XPD1sj9RbTIf3Fpq5t/2GpiXjf
    AgMBAAGjgfswgfgwHQYDVR0OBBYEFH8m9w0a39vfSS2sM2OnbZIrbartMIHIBgNV
    HSMEgcAwgb2AFH8m9w0a39vfSS2sM2OnbZIrbartoYGZpIGWMIGTMQswCQYDVQQG
    EwJUVzELMAkGA1UECBMCVFcxDzANBgNVBAcTBlRhaXBlaTEQMA4GA1UEChMHbmV0
    Z2VhcjEQMA4GA1UECxMHbmV0Z2VhcjETMBEGA1UEAxMKbmV0Z2VhciBDQTEQMA4G
    A1UEKRMHRWFzeVJTQTEbMBkGCSqGSIb3DQEJARYMbWFpbEBuZXRnZWFyggkA/X6o
    L5w++IUwDAYDVR0TBAUwAwEB/zANBgkqhkiG9w0BAQsFAAOBgQB+7NlPceHCq1M6
    +w72zuqiV9kpbQp3SiLdb/dXJLST2F1/AVUop0SdDeQnKD9yFh7YAaOBy9qMW4Rn
    BQ2va8mt/+iW9YBrmYFKrMLyyPbdqRT6UWwiUyaF4B7PcZxj/afHF6OrIktNzRhR
    5AqiTpjQNyyyd9eUo6xXDweM9JPgWA==
    -----END CERTIFICATE-----
    </ca>
    <cert>
    Certificate:
        Data:
            Version: 3 (0x2)
            Serial Number: 2 (0x2)
        Signature Algorithm: sha256WithRSAEncryption
            Issuer: C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear CA/name=EasyRSA/emailAddress=mail@netgear
            Validity
                Not Before: Jul 13 19:33:02 2018 GMT
                Not After : Jul  8 19:33:02 2038 GMT
            Subject: C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=client/name=EasyRSA/emailAddress=mail@netgear
            Subject Public Key Info:
                Public Key Algorithm: rsaEncryption
                    Public-Key: (1024 bit)
                    Modulus:
                        00:d6:29:ce:29:61:81:18:a4:ea:31:9b:e7:21:7a:
                        53:e8:4d:41:c0:13:e9:80:b7:9a:7e:d8:62:fe:7b:
                        7b:01:c0:2c:13:b8:36:44:44:ad:20:19:cc:79:3d:
                        af:73:68:74:60:bb:14:d6:32:1b:4d:34:88:57:82:
                        b4:e1:6a:ac:88:62:01:d4:f1:58:54:4a:0c:00:7a:
                        e9:01:7b:67:d9:d7:a6:cb:1d:9a:23:fd:0b:52:a6:
                        6a:05:25:40:38:79:06:20:71
                    Exponent: 65537 (0x10001)
            X509v3 extensions:
                X509v3 Basic Constraints:
                    CA:FALSE
                Netscape Comment:
                    Easy-RSA Generated Certificate
                X509v3 Subject Key Identifier:
                    ED:01:3E:B4:0B:F3:BA:F9:D8:55:56:9F:A4:80:35:89:C7:F5:DE:15
                X509v3 Authority Key Identifier:
                    keyid:7F:26:F7:0D:1A:DF:DB:DF:49:2D:AC:33:63:A7:6D:92:2B:6D:AA:ED
                    DirName:/C=TW/ST=TW/L=Taipei/O=netgear/OU=netgear/CN=netgear CA/name=EasyRSA/emailAddress=mail@netgear
                    serial:FD:7E:A8:2F:9C:3E:F8:85
                X509v3 Extended Key Usage:
                    TLS Web Client Authentication
                X509v3 Key Usage:
                    Digital Signature
             e4:9b:e2:54:9a:b4:5f:2b:4d:18:d7:bd:c8:31:66:59:e6:36:
             30:f9:44:bb:06:f0:53:43:3c:c4:ff:4b:85:af:a4:f7:de:41:
             11:d7:0d:75:96:28:f8:fc:9d:95:76:71:39:e5:d8:62:5f:a3:
             da:4e:49:fa:c2:65:8b:23:b6:97:5c:bd:df:58:d2:22:cf:61:
             90:8b:36:b9:84:62:a3:00:0c:91:4b:36:72:df:91:f8:3f:1a:
             1a:e8:62:5f:17:19:91:04:65:3e:a2:f6:a6:50:1c:6e:a8:9e:
             2b:5c
    B0Vhc3lSU0ExGzAZBgkqhkiG9w0BCQEWDG1haWxAbmV0Z2VhcjAeFw0xODA3MTMx
    OTMzMDJaFw0zODA3MDgxOTMzMDJaMIGPMQswCQYDVQQGEwJUVzELMAkGA1UECBMC
    VFcxDzANBgNVBAcTBlRhaXBlaTEQMA4GA1UEChMHbmV0Z2VhcjEQMA4GA1UECxMH
    bmV0Z2VhcjEPMA0GA1UEAxMGY2xpZW50MRAwDgYDVQQpEwdFYXN5UlNBMRswGQYJ
    KoZIhvcNAQkBFgxtYWlsQG5ldGdlYXIwgZ8wDQYJKoZIhvcNAQEBBQADgY0AMIGJ
    AoGBANYpzilhgRik6jGb5yF6U+hNQcAT6YC3mn7YYv57ZkdaPDRBTtbs+ocvuY4o
    XkSA6+aD0RNriCtbyx9VewHALBO4NkRErSAZzHk9r3NodGC7FNYyG000iFeCtOFq
    rIhiAdTxWFRKDAB66QF7Z9nXpssdmiP9C1KmagUlQDh5BiBxAgMBAAGjggFKMIIB
    RjAJBgNVHRMEAjAAMC0GCWCGSAGG+EIBDQQgFh5FYXN5LVJTQSBHZW5lcmF0ZWQg
    Q2VydGlmaWNhdGUwHQYDVR0OBBYEFO0BPrQL87r52FVWn6SANYnH9d4VMIHIBgNV
    L5w++IUwEwYDVR0lBAwwCgYIKwYBBQUHAwIwCwYDVR0PBAQDAgeAMA0GCSqGSIb3
    DQEBCwUAA4GBABAJVRifewYH7D60p2Nuo8wv2uSb4lSatF8rTRjXvcgxZlnmNjD5
    RLsG8FNDPMT/S4WvpPfeQRHXDXWWKPj8nZV2cTnl2GJfo9pOSfrCZYsjtpdcvd9Y
    0iLPYZCLNrmEYqMADJFLNnLfkfg/GhroYl8XGZEEZT6i9qZQHG6onitc
    </cert>
    <key>
    -----BEGIN PRIVATE KEY-----
    MIICdgIBADANBgkqhkiG9w0BAQEFAASCAmAwggJcAgEAAoGBANYpzilhgRik6jGb
    1uO1u26DQcmghO1hrt0nfGADNZTzVwK/GQiWZ9h3gxTtIgBHKJKmVySP5bCeFFYu
    w+3RpsXsJ5mDyb7nTryrG98kKtGSd+AsP9Mswt4rvSh4YaqEQgJMuEJZV8WgxYDO
    jHghkkHBYESUpUQOYQJBAPXJJT9xd+eJfTAP8gCq9w56RZmzBrQcid4RqyE4Kj0W
    H4NKmlsN1/6zDme3vz2WDuDm9QLGSdNGSGgcSR8ffmcCQQDfEDyPXVU1O4Ikug1D
    WwlXGEvgpSgCRxeX4k9xbGzIQIPgGJKOuzNbsaZF0DGWf7QfEBcpch0OPhDSH12m
    bv+sJ0Sd9+E48UlXyqXBaSDTsWzd3mSKR8/SaBMWqMBBzFvHSnEFAkEAiLdEGZeU
    XXpvjlx3Tv9TiPU5XHbfDyfBkFJ7HbhLWR1/N62HeCiee8d00Jw/isWgfaUJbQyu
    qb1I4B1Z346tTQ==
    -----END PRIVATE KEY-----
    </key>
    cipher AES-128-CBC
    comp-lzo
    verb 5
  • Check this out https://www.netgear.com/home/services/orbilogin/
