SchalkPetro
May 28, 2023Aspirant
Orbi RBK863 AX6000 Tri-Band slow
Hi everybody,
I'm a new Netgear user, and brand new to this community.
Currently, I'm an unhappy Orbi owner because the WiFi provided by my Orbi RBK AX6000 is SLOWER than what I had before using a ±10-year-old Google mesh system.
I expected that spending $2000 on the "latest technology" would be an upgrade of my older Google technology. But so far, it seems to be a massively expensive DOWNgrade!
I didn't notice it in day to da use of my phone or laptop.
But when we watched Netflix on Friday & Saturday nights, it was immediately obvious. The Netfilx pages take longer to load, moving between different movies takes longer, and movies take a LOT longer to load. Also, when I pause a movie and press play again, it takes a lot longer to re-start.
The Orbi satellite stands in exactly the same spot where I previously had the Google satellite unit.
Nothing else has changed. The layout of furniture in the home is still the same. The Orbi network passes through exactly the same walls the Google network had to.
The ONLY difference is replacing the Google mesh system with the Orbi system. Oh, and the Orbi has two satellites, while the Google only had one.
I *could* throw the Orbi in a box, put it away, and set up the Google mesh system again. But I'm understandably not keen on doing that after I paid $2000 for it!
Any suggestions would be highly appreciated.
Yes, this is not what one would expect. Just curious: where does an RBK853 package cost $2,000? (In the US, Amazon sells the package for $895. The Netgear web store is $899.99)
If the Google system is still available, it would be a good experiment to "swap" the systems and verify that Netflix continues to behave differently with the Netgear system than with the Google.
- SchalkPetroAspirant
Hi CrimpOn,
It's in New Zealand, so the price is in NZ$.
But I also had the heading wrong -- I went to the store to purchase a RBK853 but ended up buying the 863.
Thanks for the tip.
However, it was such a pain getting the Orbi set up -- it took me well over 4 hours, with 4 failures, before I finally had it connected to my network and working properly.
So, I'll have to wait until next weekend when I have enough time to struggle through the process again.
Everything about the Orbi so far has been painful.
Kind regards
(Duh. There are "dollars" all around the globe. "My Bad")
Wondering how this Orbi system was configured. (My only experience is with Internet Service Providers (ISPs) that use DHCP, so the Orbi will function without any configuration at all. Plug it in, and "it works". Of course, the WiFi SSID/password are what is printed on the product label, and most customers prefer to change it to exactly what the previous WiFi system was. (I have done this for over 15 years). That way, all existing devices connect automatically and do not need to be reconfigured. (And, the "bonus" is that going back is a simple matter of swapping the equipment.)
.Was this Orbi system configured using
- The Orbi 'app' ('cool', 'modern', but not offering access to any 'advanced' functions), or
- The Orbi web interface with a computer connected to the router.?
