kiwiorbiowner's avatar
Aug 19, 2023
Orbi RBR350 incompatibility with Roborock S7 vaccuum
Recently purchased a Roborok S7 robot vacuum and although it said it would only connect to 2.4g networks, it connected ok to my Orbi RBR350 (plus 1 x satellite).
Last week it fell off the network somehow and no matter what I do, it won't reconnect. I have gone through all the Roborock reset process but it can't seem to locate my wifi network. Is there any suggestions of what I can change on my router settings possibly?
Firmware Version V4.4.1.29_3.10.80
  • plemans's avatar
    I've got a roborock s7 and I've had no issues connecting it to any of my routers. And that's including RAX200, RAXE500, RBK50, RBK750, RBKE963, and multiple other models. So I'd start looking at what the orbi is connected to.
    What modem is it connected to?
    What error does the roborock give you when it doesn't connect?
    • kiwiorbiowner's avatar
      kiwiorbiowner
      Thanks, good to hear from a fellow user that has it working!
      It is a very basic Vodafone Ultra Hub, had it for a few years.
      Roborock error code is (-21012). When I try and reset the wifi on the robot, my app locates it, pre-populates with my wifi and details. Of the next 3 checks, the phone connects to the device, transfers info, but won't connect.
      Sorry, very much a novice and glad of your help.
      • plemans's avatar
        More than likely that vodafone hub has its own integrated router and it causes a double nat. Some devices don't have issues with double nat's but some do.
        A double nat happens when you cascade more than 1 router.
        https://kb.netgear.com/30186/What-is-Double-NAT
        Fixes? There’s 3 options but only use 1.
        1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
        2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
        3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
        https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
