Orbi WiFi 7 RBE973
Reply
Orbi RBS350 Continously Blinks White and Solid magenta
duduteo
I just got this RBS350 wifi 6 system with 2 satellite , however one the first few days everything work perfect.  Then one of the satellite further away from router getting 2.4ghz.   i shift my router nearest to the centre of the room, i got both satellite in 5ghz.  Than, the 1st satellite which has no problem before, is getting 2.4ghz.  it disconnected on and off often, i try power off and on, white link blinking follow by struck at magenta.  even it got connected, it still keep remain at 2.4ghz.  it was the worth wifi mesh system i ever use.  Not cheap , good brand but low standard of devices.
it very hard to get it back into connection.   Even I move it side by side to the router, i still got magenta.
Anyone got any solution? if not i got to return this junk back and change to other brand.
Message 1 of 4
ekhalil
Master
Re: Orbi RBS350 Continously Blinks White and Solid magenta
Do you have the latest firmware Version 4.4.1.29 in the router and satellites?
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208Time Zone CET (Sweden)
Message 2 of 4
duduteo
Thank for replying,  I already have the latest firmware Version 4.4.1.29 in the router and satellites however it still connection issue.  I already give up on Orbi , exchange to Asus XT8 which double up my download and upload and perfect connection at the same location i place my router and satelites.  Fully not recommended Orbi to anyone if they looking for a mesh system .
Message 3 of 4
ekhalil
Master
Good luck with your new mesh system.
In fact I have 3 satellites RBS350 connected to an RBR850 and all is working just fine.
You maybe just happened to have bad luck with Orbi, or -likely- your network had some issues.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 414 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
