Orbi WiFi 7 RBE973
Reply
Orbi satellite won't connect in AP mode
netdav
Guide
I have two Orbi 850 APs. The satellite connected fine when in router mode. I added a better firewall and placed my Orbi in AP mode. The problem is that the Orbi satellite will not connect/sync over wireless backhaul in AP mode. I've read the other posts regarding this issue but none of the solutions worked. I've tried resetting back to factory defaults and setting them up again. The Orbi APs simply will not sync wirelessly in AP mode. I'm running the latest firmware version 4.6.14.3_2.3.12. I can connect the Orbi satellite into the same switch as the router in AP mode and sync the devices, but as soon as I pull the Ethernet cable the satellite loses the connection. I need the wireless backhaul. If I can't get this resolved soon as connectivity between rooms is now lost. Going back to router mode is not an option.
Thanks,
David
Message 1 of 13
Accepted Solutions
netdav
Guide
Re: Orbi satellite won't connect in AP mode
I wanted full visibility for the wireless traffic on the Netgate firewall. It is all working now in AP mode. I still can't figure out what changed to allow the satellite tom sync wirelessly. Now that it is working I'm not too worried about it.
Message 12 of 13
All Replies
Guru
How are you connecting the RBR in AP mode to the host router? WAN port needs to be connected between the RBR and host router.
Are you using a Dynamic IP or Static IP address configuration for AP mode on the RBR? I use a static set for 192.168.#.85 for mine thats out side of the default DHCP IP address pool range.
Be sure your firewall is handing out proper DHCP IP addresses to the RBR and RBS.
Message 2 of 13
netdav
Guide
Yes, the WAN port on my RBR is connected to my router. I am using dynamic IP from the router. IP connectivity to the RBR is fine. I don't see that I can configure a static on the RBS.
I've ordered a TP-Link Deco AXE5400. Docs state it supports wireless backhaul in AP (bridge) mode. I've spent several days fighting this Orbi issue. If I can figure this out, I can return the TP-Link.
Currently I have the RBS cabled to the RBR. But the wireless seems more unstable after switching the Orbi to AP mode. I've got a bunch of wireless speakers, smart plugs, etc.  Things aren't playing nice now.
Message 3 of 13
Guru
So with the RBS ethernet connected, they don't get an IP address from the host router at all?
These are directly connected to the back of the RBR?
What CAT# lan cable are you using?
Do you see the RBR IP address on the host router?
What is the brand and model of the host router?
Message 4 of 13
CrimpOn
Guru
When the host router is providing DHCP, then you would use settings on the host router to reserve (or "assign") IP addresses to the MAC address of devices on the network, including the Orbi router and Orbi satellite.  There is no capability to assign a "static IP" on the satellite.
Message 5 of 13
netdav
Guide
The RBS won't connect wirelessly in AP mode. In router mode it connects fine.  I wouldn't think it would get a static mapping from DHCP if the dynamic pool assigned doesn't work. Either way it is DHCP assigned. It does get an IP from the router when cabled. I am having cable runs between rooms so all this may be a moot point. I'm still concerned about the degraded performance in AP mode, but my RBS isn't positioned ideally given I had to cable it to get connected.
Seems like most Mesh systems have a weakness in that the vendors assume you are going to use their routing/nat functions. Which is fine for most consumers. But I just invested in a high-end firewall and I want the visibility for the wired and wireless clients.
Message 6 of 13
netdav
Guide
It gets an IP when connected via an Ethernet cable.
I'm running a Netgate firewall. Its awesome!
Message 7 of 13
Guru
As long as the RBS are getting connected and synced via ethernet, I would give that a go.
Make sure they show up in the RBRs web page as synced and status should show wired.
Front LED should be BLUE then turn off.
Make sure the RBS web page is accessible and shows same SSID name and channels as RBR.
Last time I had mine online in AP mode it worked. Mine are also ethernet connected when I do. Though I sync mine wirelessly first, then when all synce, Configure AP mode with a static IP configuration. All change over to the host router I use. I don't have a actual firewall device. Then when all is mostly ready. I turn OFF the RBS and deploy back to remote locations and connect up the ethernet cable and turn them on. Takes a few minutes but the RBS sync over ethernet and come to ready.
Message 8 of 13
netdav
Guide
I think I'm going to have to pull the plug on the Orbi. Since switching to AP mode my Google Home devices don't work most the time. My PCs do keep IP connectivity but other things are unstable. I cannot connect to the Orbi using the app. I can login to the web page but the only thing it shows connected is the Google Nest Hub. Currently it has no Internet. All my Sonos speakers are connected. Basically my Wifi system is a mess. Switching back to router mode is not an option.
Message 9 of 13
netdav
Guide
Interesting. I thought I'd try syncing wirelessly one more time before giving up on the Orbi, so I unplugged the cable, initiated a sync, and it synced up. I have no idea why it worked. So I moved the satellite to my office to bridge the Lan and it worked as well. I'm getting the full 500Mbps that the ISP offers. The Google Home stuff is all working as well. Craziness.
Message 10 of 13
Guru
Might try the Orbi system in Router mode and use the host routers DMZ for the RBRs IP address it gets from the host router in the DMZ.
What region are you located?
Message 11 of 13
netdav
Guide
Message 12 of 13
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 4904 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
