KeefM
Nov 07, 2022Aspirant
Orbi speed seems capped to 100mbs upload & download.
We're in Spain and just moved to a new fast broadband provider. We're getting up/download speeds off their new Huawei router (wifi) of 500mbs+.
But the Orbi appears to be capped at 100ish up/down all the time? I rebooted it when I connected it to the new router. We have one satellite.
It is connected to the route by a very short Ethernet cable.
Can anyone explain, simply please, why this appear to be happening.
Many thanks
have you checked the wan port statistics? Maybe it is connecting at 100mbps speeds. A sketchy cat 5e cable could cause that.
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
- KeefMAspirant
The WAN statistics say its 100m/Full. But the port says it should be able to handle 2.5Gbs?
1. what orbi do you have?
2. If it supports 2.5gig hardwired connect, try a good quality cat 6 cable between modem/router. replace the one you have
3. what modem/gateway is it connected to?
