Orbi WiFi 7 RBE973
Reply
Orbi - unstable connection, no event logs
przemek3d
My Orbi system is unstable, the wifi disconnects often. I am getting many unstable connection notifications while having video calls.
As a side note, I do not see any event logs. I saw them after I recreated my mesh from scratch, but they stopped showing after few days. Not sure if both issues are related.
I would be very grateful for help.
Message 1 of 8
Guru
Re: Orbi - unstable connection, no event logs
What Orbi model do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Message 2 of 8
przemek3d
Hi FURRYe38, thanks for your help:
What Orbi model do you have? CBR750
What Firmware version is currently loaded? V4.6.5.8_2.0.54
What is the size of your home? Sq Ft? 3500
What is the distance between the router and satellite(s)? 30 feet or more, might be less than 30 feet in a straight line, but they are on separate floors, separated by walls - I can move it further
What channels are you using? Auto and 48 on 5Ghz
I did not answer the question about the modem router connection as this is one device. After I restarted the main router I saw the event logs for a day. Then they stopped appearing. There are also issues with NTP Settings. As I mentioned, the wifi connection becomes unstable - I need to manually switch between the primary and guest network, as one of them becomes unusable. Not sure if all of the above issues are related.
Message 3 of 8
Guru
Please post a copy and paste of the modems connection status and event log page. Use a different browser if needed.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Try using channels 1 and 40.
Try setting the transmit power to 50% on the CBR. Under Advanced Tab/Advanced Settings/Wireless Settings
Message 4 of 8
przemek3d
Thanks for the help. I changed the channels to 1 and 40 and reduced the power to 50%. After reading the article, I noticed that one of the upstream channels might be problematic:
6LockedATDMA62560 Ksym/sec40400000 Hz49.8 dBmV
I also noticed quite often the following critical event.
Sep 16 2022 22:08:07Critical (3)No Ranging Response received - T3 time-out
I hope this is not an issue with my home wirings, as that would be hard to detect. There were multiple Comcast technicians checking my wirings and signal coming to the modem. They said it was ok.
I'm attaching the cable connection (sorry for the format, it is hard to attach something readable here) to the post and pasting event logs below (they were usually missing):
Time Priority Description
Sep 16 2022 12:53:14 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 13:06:58 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 16 2022 13:06:59 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 13:26:56 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 16 2022 13:27:01 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 13:32:56 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 16 2022 13:33:18 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 13:38:55 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 16 2022 13:38:58 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 13:48:54 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 16 2022 13:48:55 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 22:08:07 Critical (3) No Ranging Response received - T3 time-out
Sep 16 2022 22:46:25 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 17 2022 00:07:42 Alert (2) CM Certificate Error
Sep 17 2022 00:10:23 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 17 2022 11:39:08 Critical (3) No Ranging Response received - T3 time-out
Sep 17 2022 11:41:16 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 17 2022 13:23:18 Critical (3) No Ranging Response received - T3 time-out
Sep 17 2022 13:35:56 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 17 2022 22:03:28 Critical (3) No Ranging Response received - T3 time-out
Sep 17 2022 22:11:48 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 18 2022 00:07:41 Alert (2) CM Certificate Error
Sep 18 2022 00:08:17 Notice (6) CM-STATUS message sent. Event Type Code: 5
Time Not Established Critical (3) No Ranging Response received - T3 time-out
Sep 18 2022 07:48:37 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Sep 18 2022 07:48:37 Notice (6) TLV-11 - unrecognized OID
Sep 18 2022 07:48:37 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11
Sep 18 2022 07:48:42 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value
Sep 18 2022 07:48:42 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
Sep 18 2022 07:48:42 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 18 2022 07:48:53 Alert (2) CM Certificate Error
Sep 18 2022 09:07:40 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 18 2022 14:27:41 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Sep 18 2022 14:27:41 Notice (6) TLV-11 - unrecognized OID
Sep 18 2022 14:27:41 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11
Sep 18 2022 14:27:45 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value
Sep 18 2022 14:27:45 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
Sep 18 2022 14:27:46 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 18 2022 14:27:56 Alert (2) CM Certificate Error
Sep 18 2022 14:37:46 Notice (6) CM-STATUS message sent. Event Type Code: 5
Message 5 of 8
Guru
What the Correct and Un-Correctables look like on the cable connection status page?
You have Criticals and Warnings that the ISP needs to look into.
If there are lots of numbers seen in the Correct and Un-correctables, this needs to be resolved as well as these should be mostly zeros seen here.
Be sure your using good quality RG6 coax cable up to the modem. Check all fittings and connections.
Power levels are with in spec however could come up just a bit if the ISP can do that.
Message 6 of 8
przemek3d
The posts keep disappearing...
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel423000000 HzLocked
Connectivity StateOkOperational
Boot StateOkOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectable
1LockedQAM 2561423000000 Hz0.0 dBmV40.9 dB8185
2LockedQAM 2562429000000 Hz-0.2 dBmV40.9 dB10362
3LockedQAM 2563435000000 Hz-0.5 dBmV40.3 dB11455
4LockedQAM 2564441000000 Hz-0.9 dBmV40.9 dB14736
5LockedQAM 2565447000000 Hz-0.7 dBmV40.9 dB10864
6LockedQAM 2566453000000 Hz-0.2 dBmV40.3 dB9258
7LockedQAM 2567459000000 Hz-0.5 dBmV40.9 dB17171470
8LockedQAM 2568465000000 Hz-1.2 dBmV40.9 dB32854930
9LockedQAM 2569471000000 Hz-2.9 dBmV38.9 dB2074114793
10LockedQAM 25610477000000 Hz-9.2 dBmV34.3 dB3190973557
11LockedQAM 25611483000000 Hz-8.5 dBmV34.3 dB5590690530
12LockedQAM 25612489000000 Hz-3.2 dBmV38.9 dB7621346393
13LockedQAM 25613495000000 Hz-1.5 dBmV40.3 dB3081217514
14LockedQAM 25614507000000 Hz-0.5 dBmV40.9 dB11024
15LockedQAM 25615513000000 Hz-0.2 dBmV40.3 dB520
16LockedQAM 25616519000000 Hz-0.2 dBmV40.9 dB310
17LockedQAM 25617525000000 Hz0.0 dBmV40.3 dB2111
18LockedQAM 25618531000000 Hz0.0 dBmV40.3 dB380
19LockedQAM 25619543000000 Hz0.2 dBmV40.3 dB270
20LockedQAM 25620549000000 Hz0.2 dBmV40.3 dB310
21LockedQAM 25621555000000 Hz0.2 dBmV40.9 dB284
22LockedQAM 25622561000000 Hz0.0 dBmV40.3 dB275
23LockedQAM 25623567000000 Hz0.0 dBmV38.6 dB260
24LockedQAM 25624573000000 Hz0.0 dBmV38.9 dB330
25LockedQAM 25625579000000 Hz0.0 dBmV40.9 dB290
26LockedQAM 25626585000000 Hz0.0 dBmV40.3 dB410
27LockedQAM 25627591000000 Hz0.2 dBmV40.9 dB420
28LockedQAM 25628597000000 Hz0.2 dBmV40.3 dB628
29LockedQAM 25629603000000 Hz0.0 dBmV40.3 dB380
30LockedQAM 25630609000000 Hz0.0 dBmV40.3 dB496
31LockedQAM 25631615000000 Hz0.0 dBmV40.9 dB628
32LockedQAM 25632621000000 Hz0.0 dBmV40.9 dB312
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA12560 Ksym/sec10400000 Hz46.5 dBmV
2LockedATDMA25120 Ksym/sec16400000 Hz43.8 dBmV
3LockedATDMA35120 Ksym/sec22800000 Hz43.3 dBmV
4LockedATDMA45120 Ksym/sec29200000 Hz43.8 dBmV
5LockedATDMA55120 Ksym/sec35600000 Hz45.3 dBmV
6LockedATDMA62560 Ksym/sec40400000 Hz48.8 dBmV
7Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
8Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
Downstream OFDM Channels
ChannelLock StatusModulation/Profile IDChannel IDFrequencyPowerSNR/MERActive Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked3159722000000 Hz-1.9 dBmV40.9 dB1246~2849000
2Not Locked000 Hz0.0 dBmV0.0 dB0~4095000
Upstream OFDMA Channels
1Not Locked000 Hz0.0 dBmV
Message 7 of 8
Guru
Power levels are ok but there are too many correctables and un-correctables. These need to be zeros. Something the ISP should help resolve. Check the fittings and for splitters. Suggestions mentioned to help on this.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1158 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
