Dazza762's avatar
Dazza762
Luminary
Dec 14, 2021
Privacy warning on iPhone when on AX4200 WiFi Mesh System (RBK753) network
I've noticed that when looking at the wifi setting on my ios devices that there's now a privacy warning when I'm on my home wifi. The wanring is: This network is blocking encryted DNS traffic.
Does anyone know what setting I need to change on my RBR750 to get rid of it?
  • FURRYe38's avatar
    Do you have Privacy Address disabled on the iPhone, this will appear if this feature is disabled.
    It may also appear if you have WPA and TPIK set on the RBR. Be sure to set WPA2 and AES only.
    • Dazza762's avatar
      Dazza762
      Luminary
      No. Privtae wifi address on iphone is enabled and I'm using WPA2-PSK [AES] security setting on the RBR
