Orbi WiFi 7 RBE973
Reply
RBK852 Cannot do a speedtest
johnny5126
Under Qos setup in AP mode, when I try to test the speed, I get the error:
The Speedtest failed to detect the bandwidth, please check your Internet connection or try again later.
I get internet service, can use speedtest.net or the app on my phone, so its not internet service.  Any ideas?
Message 1 of 10
Accepted Solutions
Guru
Re: RBK852 Cannot do a speedtest
Try setting the IP and DNS to Dymanic instead of Static...
Message 4 of 10
All Replies
Guru
Is the RBR set for static or dynamic IP and DNS addressing? I saw this issue late last year while in AP mode while using Static IP and DNS addresses. Works when using Dynamic addressing. NG fixed this in a later version of FW.
Message 2 of 10
johnny5126
I just updated to the latest firmware when I got these 2 days ago. It's set to AP mode, static ip, dns 1.1.1.1.
Message 3 of 10
Guru
Message 4 of 10
johnny5126
And that fixed it and the NTP server as well.  Another bug that needs to be squashed....
Message 5 of 10
Guru
IT has been. You can wait for next FW update or ask for the beta.
Enjoy. Smiley Wink
Message 6 of 10
johnny5126
I asked but never received a response.
Message 7 of 10
Guru
Maybe today since the weekend is over. Smiley Wink
@Christian_R
If you don't get any responce, send me a PM.
Message 8 of 10
dglsmcd_USMC
Luminary
I have the 852 in AP mode behind an ASUS router-when you go to the page in the RBR GUI which changes the RBR/RBS to AP mode it specifically says "Static" not recommended-I have used dynamic with the most recent firmware release and a couple betas without speedtest issues. FYI
Message 9 of 10
Guru
IT has been. So you can use either Static or Dynamic. You can wait for next FW update or ask for the beta.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2504 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
