- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK852 wan port is not connecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello, i have RBK852 Orbi router/satalite connected to CM1200 and it has been working great until last night when the wan port is not connecting to the internet. (magenta light)
I used an old router and it works fine with the modem and I called the ISP and they brought a test modem and it worked well with my old router but the Orbi router still would not connect.
I'm suspecting that the Wan port is damaged or hit by a storm (it is connected to a surge protected that is connected to a UPS but still...)
I'm wondering if there is a way to switch the WAN port to use on of the Lan port since it has the capability of port aggregation? has anyone been able to do so?
I did try to enabled Wan aggregation on both the router and the modem and the router still doesn't connect (magenta light)
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK852 wan port is not connecting
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Make sure your using WAN port #1 on the CM modem.
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using good quality LAN cable between the modem and RBR. CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In addition to what @FURRYe38 said, make sure nothing else is plugged into the cm1200 other than the orbi.
The cm1200 has more than 1 ethernet port but the vast majority of ISP's only support 1 device connected.
So before you follow his procedure, make sure to disconnect everything from the cm1200 (including coax).
then reconnect coax and follow the power on/startup guide outlined prior.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The issue now is that the satellite is not connecting, not sure if it is because of “bridge mode”
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you feel the Orbi is damaged, I would contact NG support and ask about RMA options.
https://my.netgear.com/support/contact.aspx
Did you put the RBR in to AP mode?
